6 Nov 2021
Hi.
The oven on my 110 continued to spark when lit. Switched it off and tried to light again. It now sparks but doesn't light.
Tried the other oven and exactly the same thing. Continued to spark when lit and after switching off would not light at all but does spark.
Any ideas please?
CBW
26 Sep 2019
North
Is there definitely gas present? Has anything fallen onto the pilot assembly? Does food often drop onto the pilot assembly?
6 Nov 2021
Yes there is gas. I can smell it although it won't light using a lighter. It's both Ovens and the second oven is barely used.
6 Nov 2021
I don't suppose anyone has any input please? The issue is still not fixed.
7 Jan 2007
Make sure the clock isn't flashing '00:00' put a time in press the first two buttons then + or -
Then one at a time turn the oven on and off several times ....do you hear a clunk ?
If you do the oven should light with a taper. When on for a couple of minutes should flame up. Same with both ovens .....no clunk = electrical fault no bigger flame ( stays small ) fsd fault.
Spark or no spark on continuous sparking.
Generator or HT lead or electrode fault.
