I was just browsing the Ratedpeople.com site (as you do) and something caught my eye in the diy guides electric section.
http://www.ratedpeople.com/c/advice/diy-guides/guides-electrics
Now I'm no electrician, but aren't they giving somewhat misleading advice? For example, under "adding a power socket" they say:
"8. Make sure each wire is connected to the corresponding terminal. The black wire connects to the neutral terminal; the red wire connects to the live terminal, and the blue wire to the ground terminal"
and under "replacing a plug":
"7. Once the insulation is removed, you should see the three different colours of wires: red, brown or yellow/green and blue. The different coloured wires represent the three types of wire: earth, live and neutral"
As for replacing a light switch....
http://www.ratedpeople.com/c/advice...s-electrics-lighting/replacing-a-light-switch
Is it me, or are they are a tad confused?
