C -chitty
E -exspensive
F -factors
E -exspensive
F -factors
Has anyone had any negative experiences with CHINT products.
Yes.
They are absouloutly disgusting build quality.
thats the trouble with RF,he never says what he means![]()
Can RF elaborate on the build issue with CHINT.
Surely 3rd party approvals to the major European test houses together with the fact they are the 3rd largest LV manufacturer in the World is prove that their products have been passed for Quality.
Certainly.
I've only ever fitted one ot those CUs as a customer supplied it (kind of speaks volumes).
I have vowed never to use one again.
From the one I fitted I noticed the following
They look and feel cheap.
The case is too thin and flimsy, meaning if you mount the CU on an uneven wall the cover will not fit.
The plastic cover screws are arkward to line up with the pegs on back part, and end up snapping
The lillte perspex cover sticks half way open / closed
The busbars and neutral links are too small.
The thread strips on the screws of the main switch.
The earth bar drops out of the casing when you try and fit a 16.0mm² earth.
There is not enough room to keep your work inside the CU tidy
There is not a large enough range of CUs
There is not a large enough range of OCPDs
The plastic half dinrail breaks
The half DIN rail means you cant install clocks and contactors
It is impossile to route tails into the cu from the bottom half of eiter side
The CU is not supplied with backed out screws
MCBs are not supplied with backed out screws
CUs are not supplied with a good selection of circuit ID stickers
Yep & when the customer tells you he only paid £20 on ebay for them you just know it's gonna look a bag of ****e .They look and feel cheap.
Again gotta agree, unless the surface is dead flat you are stuffed. The likes of Wlex & co do have a bit of give, Hager are even better with the punched fixing lugs for uneven surfaces....Mr Chint might think about taking a lookThe case is too thin and flimsy, meaning if you mount the CU on an uneven wall the cover will not fit.
Stick with (in no particular order)
Merlin Gerin
Square D
MEM
MK
Hager
They actually make quality products, and don't need to tout their products on an internet forum to get their sales up.
I will forward your points to China as I am sure they would wish to make things better. Thanks
I thought that CHINT was mean't to be a UK manufacturer![]()
I always mount my boards on boards, if u c what I mean....
Then theys is always flat!
