Hi all.
The problem I have is that my RCD started tripping at random times (firstly occasionly some early evenings). Reseeting the RCD bought everything back to life. Then last weekend it tripped and while the wife kept trying to reset the rcd I went round the house disconnecting everything I could. It still wouldn't reset. I then turned off all the breakers and at first it still wouldn't reset. Then after turning the breakers back on and then off again it did finally reset. Suspected a problem with the downstairs ring main (this is separate to the kitchen main and has very little on it). Eventually by removing a neutral from the last socket on the ring the RCD could be reset. Any ideas A) what the problem is ?
B) Why by disconnecting one end of the neutral this has allowed the rcd to reset?
