Issue....
A bayonet light fitting was replaced like-for-like, as it got damaged and everything worked fine for a week.
Then all of a sudden, when the pull cord was pulled, it would trip out the RCD (100A, 30mA).
Inside the bayonet fitting was a red, black and earth wire. If these are disconnected and put in to connector block, the RCD will still trip. So this can eliminate the new fitting.
The pull cord switch was replaced with two others, know to work fine on the circuit. This didn't solve the problem either.
Turning all the other lights on the circuit off, then trying said pull cord still trips the RCD.
The pull cord circuit has an extractor fan on it, which when disconnected and put in to connector block doesn't help things.
Nothing has changed in the building. I.e, no screws or nails have been hammered in to the wall.
Any ideas when the next step would be, and what to check?
