RCD
Some instruments will stop a test if the voltage increase is too great, in this case the voltage increase @ 150mA is going to be somewhere in the region of 16v. I doubt this will be enough to cause the test to stop tbh, can you check the instruction manual?
yea can do. i pressed the type button and then tested and eventually got a reading of around 7ms
