Hi
Sorry if this is in the wrong forum.
I'm not a tradesperson so please bear with me as I'm just looking for ideas for a fix.
We have a rental property that has some issues after the last tenant left.
One issue is that the radiators in the living room, under windows, look like they were fitted directly to the plasterboard and the plasterboard has started to bow or bulge out a bit and the brackets for the radiators have come loose. I think someone has obviously been leaning on them more than once.
I've no idea where the studs might be in the wall or if there actually are any. I've tried a stud finder and it seems to beep every time I move it so no idea what is going on.
I'm looking for the most cost effective (i.e. cheap) way of fixing this so I'd rather not have to cut out any of the plasterboard as the walls are currently wallpapered with textured paper. If we need to start cutting out sections of wall then we'd probably need to redecorate the whole room.
I was wondering about an option of fixing a piece of plywood or MDF to the wall and then fit the radiator to this. And thinking it may be useful to get fixings long enough to fix the plywood through to the brickwork at the back (external wall).
Does this sound reasonable or is it a terrible idea ? If it's doable would plywood or MDF be better ? And what fixings would be best to use ?
Thanks for any suggestions.
