Fixing wall cabinets to plasterboard
8 Dec 2008
Kent
I have a 3 metre run of kitchen wall cabinets to hang to a plasterboard wall and wondered what the best fixings to use are. I've looked around and was thinking of either using metal hanging strips cut to the length of each unit and hang the units on with the adjustable hanging clips through the back of the units, or locating the studs and fixing straight to those. I just want a strong reliable and safe fix. Any advice gratefully excepted. Thanks
The metal hanging rail would be best. Don't cut it to the width of each unit, but cut it 35mm shorter than the length of the run. Screw the rail to the studwork through the plasterboard. Every cabinet side will have to be cut to accommodate the rail,(at the back where the brackets stick through) apart from the end panels at either end of the run.
Then hang the wall units off the rail using the brackets supplied with the wall units. Easy. :wink: :wink:
Hi. Thanks for a quick reply. Can I ask why you say not to cut hanging rail to width of each unit?
If you cut to the width of each unit you may find there is only one stud behind that unit so won't get a good fixing. or worse still a 300wide unit may come between two studs as they are usually at 400mm centres :cry:
Jason
As Jason says, keep it at almost full length of the run and you will definitely find studs to fix it to. :wink: :wink:
Or you could cut out a strip of plasterboard at top of cup' b about 100mm wide and replace with 12mm ply screwed to stud work, would not require any cutting of units.You can then use fittings supplied to hang.
That's a really good idea Foxhole. That way I would be able to fix the normal 2" or so hanging rail brackets(you know what I mean) where I need them anywhere along the length of the plywood, knowing I have now have the strength of the overall run fixed to the studs.
Also thanks JoinerJohn too for your advice. I have taken it all into account. Cheers :D
