I have a meter and fuse box in a under-stairs cupboard accessed from the kitchen. I would like to use this space for a fridge/freezer, and so would like to have the meter moved and the fuse-box replaced by a CU. It could for example be moved to the other smaller under-stairs cupboard, accessed from the hall. This would be easiest from a moving the supply cable point of view in that it is just the other side of a brick wall.
In this smaller under-stairs cupboard is also the gas meter. Is there any reason why I couldn't/shouldn't have the two in the same cupboard?
Note I am not planning on doing the moving myself, just thinking ahead.
Cheers
Cheers
