re start up
10 Oct 2008
Wiltshire
when i press the button to turn my pc on it says operating systen not found any ideas as to what that means and how to fix it
Check if you have a floppy in one of the drives or a memory stick in one of the usb's your pc thinks are 'rescue' disks'
It means that it can't find a master boot record on your disk.
This could be because the BIOS can't find your disk.
This could be because the disk is disconnected, so check the connections.
Otherwise, you have a disk problem that needs diagnosing.
Some disk problems are physical and irrecoverable; some aren't.
Either:
You have a bootable floppy disk, USB memory stick or CDrom in the drive, and it does not contain an operating system (windows)
Or
Your hard drive is broken, has lost some (possibly all) information on it including Windows.
First, remove all CDs, DVDs, floppies, USB disks etc and try again.
If it still says "not found" take it to a local computer shop (not PC world) and get them to give you a quick opinion on the state of the hard disk. You can also boot from the Windows XP setuip disk and make as if you want to install XP. XP will examine the disks in the machine and report on any hard disks it finds
If it says "no hard disks are available in this computer" or finds a hard disk but it is entirely denoted to be "unpartitioned space" then your hard drive has likely suffered a failure of such a degree that you should run some dos-based recovery software to recover your files, then buy a new drive and start again.
If the hard disk is reported as something like:
C: NTFS xxxxxxMB free space
Then the hard disk still has partition information but is likely missing some vital files. Reinstall XP on the drive. If it offers you the opption to re-install the operating system files but keep all your settings, then it has found enough of your data to proceed from.. otherwise you'll have to reinstall as if from afresh and reinstall all your programs. Your data (photos, documents) will be retained UNLESS YOU CHOOSE TO FORMAT the disk.
Investigate the root cause of the missing files:
If your kids deleted them, no problem. If the hard disk is old and dying, back up your data, buy a new disk and start over (again)
Either:
Fair point.
...Or
That's a very poor description of the set of possible causes.
Before that he needs to make sure that the drive is still connected.
Do you have an example of this magical DOS-based recovery software?
This is very bad advice if the drive has a physical fault. It needs to be tested before anything else is written to it.
Way off the mark - the MBR isn't being found, so missing files are somewhat irrelevant.
