- Joined
- 17 Dec 2010
- Messages
- 1
- Reaction score
- 0
- Country
I redid the bathroom 3 years ago. It was mostly DIY, but I got a "professional" tiler to do the tiling, so it wouldn't leak... and now it's leaking.
It's a bath with mains-pressure shower over, and I use the shower every day. The walls around the bath are tiled. Some of the tiles are no longer properly attached - I can poke the corner of a tile and see it move. I can also see huge amounts of water flowing into the kitchen below, and water marks on the other side of the bathroom wall.
The bathroom walls are rather elderly plaster (not plasterboard) on brick. The tiler just used normal "waterproof" ready-mixed adhesive/grout, bought from B&Q, which of course isn't actually waterproof.
What's the best solution?
I guess all the tiles are going to have to come off and be replaced with new tiles? Should I tank the area behind the new tiles? Should I use waterproof backing boards, and if so should I take the plaster off or just put the backing boards on top of the existing plaster? Should I use epoxy grout? Is there something else I could do?
