- Joined
- 1 Apr 2016
- Messages
- 180
- Reaction score
- 1
- Country
It's more dependent the length of the journey. It needs to have a good run to do a full active regen. Passive regenerating does help a little bit but it needs an active regen which is dictated by the ECU to clear it out properly.
The problem is if they get too blocked and the back pressure reading is too high the ECU won't allow a regen. Then you need the software to plug in and force a regen. They are a massive pain in the ass. You get more power, better throttle response and more MPG without one.
My 330d is 300 bhp and 500 lb.ft with a DPF and EGR delete and a map but I've had 48 real MPG from a tank before.
