The plumber did the plumbing for a shower before the electrician got the wiring ready and he's gone on holiday so I'm trying to want to finish it. Shower fits on with a brass compression elbow, but attaching this to the pipe makes the shower sit 15mm too far out from the wall. The pipe is buried too close to the surface of the wall to dig it out a bit so the elbow will be in the right place. Is there a better fix than chopping out a chunk of the wall and fitting a 180 degree "half-loop" so the elbow can sit further back?
Had an idea, what is the very slimmest solder elbow you can get? There is enough room in the shower to have the elbow face up and the wiring enter from a different location and without the compression nut can cut the pipe shorter.
Fixed my own problem, ask the B&Q to measure their slim elbow for me and it will fit doing that. Maybe that was the plumbers plan, can't ask him since his phone is off.
