I have some redidrivers. The screws that come with them only go in a few mm. Is this right? When the redidrivers are put in place does this screw go deeper? If so how, when there is no thread inside the redidriver? Do I just force it?
The screw should be the same size (or very slightly longer) than the redidriver.
You won't be able put the screw in by hand if thats what your thinking.
Screw it in till it locks tight.
Cheers stric,
When you say the screws can ve very slightly longer, how much longer. The ones that came with these are probably going to sit 1cm out of the redidriver even if completely filling the hole. This seems a bit strange to me.
