Reducing height of old floorboards for reuse
29 Sep 2009
Edinburgh
Hello,
I've taken some old T&G flooring boards from a skip to use for a floor in a small room (10m) in an old cottage. Current flooring is 18mm chipboard but the boards are 28mm x 135mm so I need to lose around 10mm on the boards - maybe slightly less as the room was carpeted.
I don't know what type of wood the boards are - the bare bits I would describe as light salmon pink in colour but the wood 'looks soft' if that makes any sense.
Is 10mm too much to try removing with a belt sander (assuming I can get one) or an edger? Would it be better to try planing the boards down before fitting then finishing with a sander?
Would a pic of the boards help?
belt sander 10mm = 10-20 mins a foot
planer thicknesser around 3 passes 3 seconds per ft 3 time so 40-60 seconds a plank take your pick ;)
Many thanks Big All - if there's a risk of me finishing too quickly I'll go for the sander.
sixeighth
