Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
im refitting and replacing an outside tap ( with check valve). the underground pipework is black plastic stuff, is this the same as the new blue mdpe and what are the best fittings to use
Back plastic pipe is imperial & blue mdpe is in metric sizes. Black plastic also has a few different classes of pipe with C & D being the most common, if you have a meter or so of pipe exposed you should find some writing on the pipe telling you the size & class of pipe.
