Hello everyone. Is there an optimal ratio between rise and run in a gravity loop (thermosyphon) between a wood burning stove and a cylinder? Ive heard it said that 1 in 5 is the minimum advisable for a reasonable flow rate. Is this true? And if I have an insulated flow pipe going up 20 feet and then back down 15 to the cylinder should I assume the rise to be 20 foot or 5 foot? (come to think of it would there be any other advantage in this setup?) Also is there an optimal pipe size for gravity flow systems? Any help with these questions would be greatly appreciated.
