Relocating and replacing Stopcock
28 Jun 2021
Hi
I need to relocate and replace stopcosk in the kitchen. Can I do as in the first photo below? IE: Cancelling the grey stopocck and put in the new location indictaed?
Can I use the Peglar full bore 15mm PN16 shown in second photo?
Any considerations to take into account?
TIA
Can I use the Peglar full 15mm PN16 shown in second photo?
Yes to all, as long as the new position leaves enough room for the dishwasher.
What about extending into the space to the right, thus leaving access?
Total space is 600mm. The dishwasher is slimmline 450mm wide will be on the left and 150mm base unit on the right. I will put opening at the back of the base unit to access peglar valve handle off and on as required. How does the plan sound??
If I was doing the job I'd have to replace the section of copper between the old and new locations so it was a nice 90 degree bend clipped properly anything else would drive me mad.
You've got two threads going, I can't keep up! As in other thread, a couple of us asked what is either side of this space?
Outside wall on the left and kitchen sink unit on the right, waste and cold supply all plumbed already.
that's looked fine but will be having 450mm slimline dishasher on the left and 150mm base on the right, will be easy enough to make a small opening at the back of base unit to access the lever, I will put the photo again, sorry 2 threads in parallel.
