Remounting Rads/Tail nuts and Honeywell TRVs
DrG
20 Jul 2008
Cambridgeshire
Hi Guys,
I have just taken two rads off so I can decorate. I am having a real problem doing the tail nuts back up onto the TRV’s. both are Honeywell. The rad position relative to the TRV on both is fine. When you tighten the nuts it seems that it is biting for a couple of rotations then the nut just slips then you are back to square one.
I thought it was something funny with the first rad but as the second one is doing it clearly I have missed something here. Taken plenty of rads of in the past but none had TRVs
What have I missed? I do feel quite stupid on this one.
Thanks for your help
David
Hmm, I think you might be right. Looking closely at the TRV it is completely out of square relative to everything. I have tried twisting it, chocking up the other end of the rad slightly.
I think the YTS boy was on duty the day the system was installed as all the rad pipes are out of a concrete floor and are in the right position for the end of the rad but the valves were obviously ‘forgotten’ about so all the pipes have a kink in them to pull them away and give space for the valve.
Any suggestions?
The only thing I can think to do now is to drain the system, remove the TRVs from the pipe work, mount the TRVs loosely to the rads then remount the rad and TRV to the pipe work.
sounds like the best idea
just don't pull on the pipes to much if they are straight into the solid floor.
