Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
There looks like two holes either side of the spindle have you tried putting pin nosed pliers in the two holes and removing the disc looks like it may need a special spanner like angle grinders do.
Hi footprints,
Yes the two holes accepted to pins that were on the tap handle. There is then a 3rd hole in between that has a screw up into the handle. From what I see the handle could only be removed by removing the disk and exposing the underside and also the tap valve.
