Hi All,
I have a toilet I am going to replace that is fed water from a tank in the loft (via a pump). The toilet has a wash feature and was fitted for the previous (disabled) owner. It has been nothing but trouble so its time for it to go, so to the issue...
There is a dedicated 50 Gal tank in the loft that feeds a pump (via a flow switch) and the pump feeds the loo on the floor below. The feed pipe out of the pump to the loo has an Expansion vessel fitted (I don't know why as it all cold water). I have no issue with the removal of the tank, pump and related bits except the Expansion Vessel (I have never worked with them), do I need to "discharge" it before removal of the pipe work or does it 3.5 bar of charge not leave the device ?????
I did say I have never used them, although I DO understand what they are for (in hot water systems) and I have carried out most of the re-pumb on the rest of the house (water only), had a CORGI man in to do the heating.
