I want to redecorate the walls in my dining room but the previous owner has glued plywood with an imitation wood facing to the walls using contact adhesive.
Now it is very easy to remove the plywood panels but it leaves old contact adhesive on the plaster surface.
I can't paint over this because it is just too rough, with the swirl marks from the adhesive comb showing through. The adhesive won't scrape off and it won't sand.
Any ideas how to deal with this problem?
