Renault Clio 1.2 intermittent starting problem.....
8 Nov 2007
East Lothian
hi
my 1999 1.2 Clio has suddenly become hellish at starting, particularly first thing in the morning or when left for long periods.
the problem has been here for a good few months now. I try to start the car and nothing happens. Just a single clicking noise from the glovebox area. All the dash lights come up as normal and the radio comes on. Cant be battery. The immob light goes out as normal, so it cant be that. It can take around 30 turns of the key before it finally starts. The car is fine when its been running and will start again easily if its not left turned off for a few hours. There are no problems when driving, it revs and idles fine and doesn't cut out.
i've had the top dead centre (crank) sensor out a few times and cleaned it and the connections. don't think its that.
ive checked the spark plugs and they are in good condition. The engine earth strap is also in good order.
All connections to the starter motor look good, no rust and all tight.
im at my wits end now. can anyone think of anything else that may be causing this problem?
someone on another forum mentioned it could be a fault in the starter motor. ive got it booked into a garage for next week, but id have liked to have sorted this myself if possible.
ive also replaced the key fob batteries as a long shot (someone suggested that!) But again, not the problem.
it would appear that something has got worse and perhaps become broken/faulty as this issue has steadily got worse it the last few weeks, to the point its every day now.
Help!!
thanks.
Same symptoms as my Escort td, when the starter motor failed at 100k.
Wotan
Does it turn over, when you turn the key?
yeah, but only after between 10 or 30 turns of the key. whhen it does eventually fire up the engine is sweet. As i said, when the engine is running there are no problems at all. Its only when car has been left 'cold' for longer periods, that it plays up and wont start. Im thinking duff starter motor now.
car has only clocked 45k, not high mileage, but i suppose that counts for nothing.
If it doesn't turn over, the starter motor's had it. Pretty simple DIY job.
s0ds law!, the car was fine the day before and on the day i took it to the garage, started first time throughout both days and my garage couldnt find any problem! (started fine for him to 1st thing in the morning!) He did however, replace the connector to the thin wire to the soloniod. Lets hope that was the problem, but i think i'll be back here soon with more tales of woe......
(dont think he hooked it up to any computer so no proper check for errors etc.)
But how can a car not start 1st time from cold for almost 2 weeks solid then suddenly correct itself? Very, very odd.
hi i have a renault clio 1.2 2001 n over the last few weeks has been getting worse at starting in the morning luckerly enougth we got bck from manchester fine but now it dnt start at alll. we have changed the crank sensor but that didnt work my next door neighbour is a mechanic and he thinks it could be a loose connection in the connector cable could anyone help me solve this problem as were running out of ideas
