Hi. Just joined the site as have found other posts useful in the past. Just bought a 60 year old house to rennovate. Stripped wallpaper anticipating re-skimming walls, but have the following questions to which any answers would be appreciated;
1) I read conflicting view about gaps between boards when boarding a ceiling or wall, anything from no gaps (butt tight to each others) to 3mm. If I aim to board (square edged) and then tape and skim, do I leave a gap (between boards and at joins to walls) or not? are the rules different for wall and ceilings?
2) I am replacing skirting board and architraves, but hoping to re-use door linings. Given that the linings are currently flush with the old plasterwork, after reskimming they will be recessed behind the new plaster finish. I thought that skirts and architrave went on after plaster finish, but in this instance should I get the architraves on before getting the walls skimmed?
3) There are various placed (particularly around windows) where the plasterwork is off down to the brickwork. Is it OK to apply a reasonable careful bit of patching plaster to these bits expecting the skim coat to make the patching indistiguishable from the rest of the wall?
4) The external corners of the plasterwork are finished with curved wooden strips. Im a bit concerned about just skimming over these, but if I try to replace them with metal corner beads, there will be a thickish area beneath the new beads which is unsupported (the wooden corners are recessed into the plasterwork) - what is the best way to go here? I don't think metal beads will go on over the wooden ones rather than replacing them, but does anyone think that might be an option given only skimming over the top?
5) I need to get rid of a small upstairs fireplace - can I just remove fireplace, frame out and nail plasterboard across, tape and the just skim over?
6) I have the reverse problem with the skirting that I have with the architrave. The old skirting was recessed into / under the plaster rather than nailed on flush after plastering was finished. I therefore have quite a big recess over which new skirting needs to be fitted (which will get a bit deeper after new skim coat). Should I wait until after skimming and then attempt to do a lot of packing out to get skirting on flush, or try to get skirting on first (like the architrave) and then skim down to it. Also is there and alternative to packing out (e.g. getting in a load of patching plaster at the bottom of the wall where skirts have come out, and then getting skim coat over walls extended down over patching plaster and then putting on new skirting after skim)? I'm not to sure how good an attachment I'll get for the skirting if nailing / screwing into a couple of inches of patching plaster!
Any help much appreciated - doubt it'll be the last post I make! Thanks
