Thanks I reserved it this morning for a job tomorro. Have you rented similar things from HSS before and got the chiseal bit with the drill?
Great answer Rich but surely you mean "causes less damage".SDS breakers are great for demolition but you need to be careful using them to chase existing plaster/block walls. You can do a fair bit of damage loosening the surrounding plaster if it’s of any age & even loosen the mortar joints in the block work below if you’re too “gung ho”. If you have an angle grinder I would advise you make a vertical cut either side of the chase to prevent vibration loosening the adjacent plaster. Personally I still prefer to use a bolster/cold chisels & club hammer, takes slightly longer but doesn’t cause any damage.
I stand correctedGreat answer Rich but surely you mean "causes less damage".SDS breakers are great for demolition but you need to be careful using them to chase existing plaster/block walls. You can do a fair bit of damage loosening the surrounding plaster if it’s of any age & even loosen the mortar joints in the block work below if you’re too “gung ho”. If you have an angle grinder I would advise you make a vertical cut either side of the chase to prevent vibration loosening the adjacent plaster. Personally I still prefer to use a bolster/cold chisels & club hammer, takes slightly longer but doesn’t cause any damage.
When I looked into this a couple of years ago it was cheaper to buy Srewfix' entry SDS drill for about £20, came witha chisela dn a couple of drill bits.
