Replace Honeywell 6400c
27 Nov 2016
bought a hive today and installed it seemed to work but receiver keeps going red after a while . Think I'd have preferred a nest so am going to return and get a nest which I'll place where the old thermostat is
Here is a pic of my Honeywell 6400c backplate
Left to right they are labelled N L 1 2 3 4 far left is earth I believe ?
It's an ideal boiler with hot water cylinder and an old style Honeywell dial thermostat downstairs boiler is ideal classic ff360
There is a Honeywell junction box so would that make it sundial y plan?
The backplate didn't fit so I swapped backplate over replacing cables in same terminals
Have I done something wrong causing the red light or was it just losing connection
I didn't disconnect the thermostat nor join cables as I read turning it up full did same?
Sorry for all questions any help appreciated
The wiring on the Hive is identical to your old wiring. A red light suggests a problem with the wireless signal to the thermostat, and to contact Hive for support.
If your walls are thick stone or contain a lot of metal, or the stat is a long way from the receiver, you may have problems with any wireless thermostat. A lot of houses are filled with wireless signals, which can interfere with one another. Placing the receiver too close to things like the boiler or other large metal objects will also reduce the signal range.
As you have a wire in the hot water off terminal it is likely you have a Y plan system.
Disconnecting the existing thermostat cable from the wiring centre, and fitting a link in it's place is a good idea to prevent someone accidentally turning the old stat down.
The Nest is a wonderful piece of kit, works well and has a very tactile feel, but beware the fiddly terminals on the Nest receiver. They're very small, even for 0.5mm2 cable, and some require two wires in one terminal.
MM
The hub is at bottom of stairs with direct line of sight to the receiver I had the stat right at top of stairs and tried the hub at top with home plugs it still did it ?
Would a nest wire in the same way? Also my thermostat has 3 wires will the nest be compatible if I replace the stat and have it wired in
Cheers guys
The boiler is behind the wall where the controller is placed not a lot I can do there it's over the 30cm it says
Will nest be a better bet as its wired thermostat ?
