Replace red and black 10mm cable to loft conversion?
25 Nov 2006
London
Hello
I’m doing some renovation and I have a loft conversion which has its own small CU for its light and sockets. It’s fed by a 10mm cable from the main CU on its own RCBO.
However it’s black and red and I wondered whether it’s considered old.
I obviously won’t be attaching it, but I could run it up there for the electrician to finish off. Should it be brown and blue cable by now?
Ay, not the best method as it may not achieve discrimination.
Is the main consumer unit full?
If it tests fine then it’s okay.
Is it PVC?
Only if you want to spend more money.
Thanks all. I just looked at Building Regs and it looks like the conversion was done in 1991.
I’ve got no problem with it, but I wondered if it’d give a better impression down the line if the house was ever sold.
Had to Google that and still don’t understand!
As the supply, both the lights and sockets, are fed from the single RCBO from the main consumer unit, no one can be for certain which RCBO/RCD/MCB will trip first, whether at the main consumer unit, or the one for the loft conversion.
For example, if the socket circuit developed a fault, the RCBO, one at the main consumer unit, may trip first, affecting lights for the loft too, leaving the room in darkness.
It’s not much of a biggie.
Enter the keyword “selectivity in electrical circuits UK” on Google.
Thanks Jurassicspark.
So does that mean it would be better to have the loft lighting and sockets as two separate circuits from the main CU and forget about the loft CU?
It’s not a requirement.
But tell me this, how many time have you experienced the scenario which I’ve mentioned above?
Yes, what’s the point in all circuits tripping when just one could.
So it’d be more useful to run a lighting cable and a socket cable to the loft?
This may be where I feel out of my depth and leave well alone. Do the cables run to the loft CU or does that become redundant? If so would you have to run two 2.5mm cables for the ring? Thanks
It would have been, and if doing the conversion today the more usual choice would be to have a circuit for the lighting, another for the socket outlets and perhaps more for other things if they were required.
That could be circuits just for the loft, or extending those which already cover other rooms.
For reasons no one will ever know, someone decided that installing a single large cable was the best option. Perhaps it was at the time, which would have been when RCDs were only needed on a few circuits.
If it was a ring, then 2 cables are required.
Other types of circuit are available.
What's there may not be the absolute ideal, but there is nothing particularly wrong with it, so unless you want to spend a pile of money and time changing it, probably best to leave it just as it is.
A radial will be fine for a loft. 2.5mm cable, 20A circuit protection.
But if what you currently have works for you, leave it alone.
Thanks, it does work so I’ll leave it be. Everything else in the CU is blue and brown so it’s not too ancient.
