Most commonly on two way switches the "common" is marked with a "C" or a "Com", and the other two are marked as "L1" and "L2".
on some switches "L1" are intended to be used for 1 way switching but on others "L2" is used instead.
On some switches they are not marked as Com, L1 & L2 but rather as L1, L2 & L3 so it can be a bit confusing.
There is more than one way to connect two switches in the "two way switch" configuration too.
So, overall, it can be a little confusing.
There are 3 basic ways of installing lighting circuits too.
One way is to put the switching wires in the ceiling rose or light fitting.
Another way is to do the same but inside the switch back box.
Another way is in a separate junction box.
Any installation (your home for example) could all be wired similar but might be wired with features of 2 or 3 of those systems.
And, just to make things even more complicated, there is also something that is described as a "Two way Hamburger" amongst other things, that is rare, I think, but adds another potential danger into the mix.
By now you might be thinking that it would be easier to land a satalite on the Sun, you might be correct in that line of thought.
Good luck, as always stay safe
