Hello,
I would like to fix a simple table lamp that that has been giving off a burning smell very soon after it is turned on. Different bulbs and even those rated well under the stated 60W limit of the lamp produced that same smell.
I've completely removed the bayonet fitting and the power cable, which seems to have been badly twisted somehow. I'm hoping that's the simple culprit for the fault that a new cable and holder will fix.
I suspect I'm overthinking it, but I've confused myself to a standstill in trying to find a compatible replacement for the lampholder. I keep seeing "for ceiling fitting only" on what look like ideal candidates. I realise those that include switches will be for table lamps, but I'd rather fit a rocker switch instead.
Would a kind soul confirm or rule out these as acceptable candidates? Apologies if I haven't provided enough information as yet...
Thanks in advance!
https://www.diy.com/departments/propower-lampholder-l-80mm/833017_BQ.prd?icamp=recs&rrec=true
https://www.diy.com/departments/mk-lampholder-l-82mm/189631_BQ.prd?icamp=recs&rrec=true
https://www.screwfix.com/p/mk-cordgrip-lampholder-bc-white/18465
https://www.screwfix.com/p/crabtree-bc-cordgrip-lamp-holder/23150
Thanks in advance!
