Hi Guys
Can we forget all my previous posts on temperatures, etc. The thermometer that I had was naff. Here are the proper readings.
- Alpha CB28X boiler
- Boiler is in the kitchen. Standard 2 floor house. Kitchen leads to dining room then living room (divided by an archway). Hall, bathroom and 3 bedroom upstairs.
- Boiler on full, trv's all removed except for the spare bedroom as this TRV was not shutting off the other week when plumber tried to remove rad (TRV closed fully).
*Boiler - Flow F87.8 Return R43.7
*Kitchen - F79.3 R49.7
*Dining Rm - F81.9 R41.9
*Living Rm - F84.0 R50.3
*Bathroom - 80.3 R74.5
*Hall - F82.2 R49.1
*Daughters room - F80.7 R56.0
*My room - F79.7 R51.3
*Spare - did not balance this as the TRV does not turn off when I open or close LS.
When I set the LS to the above temps, I was getting good heat in every rad except for the problem one in the dining room. When I had all rads off except for the kitchen and the dining room, the boiler was pumping the water but the hot water never went to the bottom of this radiator. My daughters rad is a bit like this but it has improved more than it was before (ie a bit warmer at the bottom but not boiling).
As you can see from the temperatures above, there is a big difference in temperature between the flow and returns. If I take the living room rad for an example. There is 33.7 of a difference but the radiator was roasting warm at this point and I saw no need to open the LS any further as surely this would take the flow from the other rads?
I got the above readings on friday night. When the heating came back on on saturday night, I found that some of the radiators were not heating up all the way to the bottom. Ie I had to open the LS on my bedroom, bathroom and hall. Otherwise, the rooms were not heating up.
Also, the dining room (problem rad) LS is fully open and yet the rad does not heat up properly to the bottom, even on start up when the room is cold. I also took surface temperatures from the radiator on friday. All temps taken in the centre of the rad length. Top 63.1, Middle 57.6, Bottom 48.5.
I am really confused as to what could be the problem.
I really appreciate everyone time and effort taken to try and help me with the problem. The one good thing is that I am beginning to understand a bit more about how the system works.
Fluff
*Hall - F82.2 R49.1
Fluff
