- Joined
- 23 Dec 2019
- Messages
- 37
- Reaction score
- 2
- Country
Can someone please help advise whether the replacement glazing unit I intend to buy will correctly fit in my existing uPVC door. I am primarily concerned that the thickness of my existing unit is about 27mm, whereas the replacement one I've found online is 24mm thick.
Here's the full details in case it helps.
The lower window unit on my uPVC front door shattered (from a stone), and I've taken out the plastic beading and removed the entire, previously sealed glazing unit. It's rectangular, and seems to be a fairly standard size (660mm x 680mm) but has a form of frosted glass.
I obviously want to buy a replacement glazing unit.
The glass itself is 4mm thick (which also seems to be standard), and the whole sealed unit itself (with silver foil surround) is about 27mm thick (perhaps, 1 and 1/16 of an inch thick?).
I've only found one possible online supplier:
SealedUnitsOnline
and they seem to do provide an almost equivalent unit except that it says it is only 24mm thick.
Will it be relatively easy to 'pack out' the additional space to the uPVC beading, or should I really try harder to find a more exact replacement glazing unit? Can anyone suggest any other suppliers I might try for a more exact match?
Also, is there a particular sealing 'gunk' I should use to seal the glazing unit to the uPVC beading? [I needed to scrape off some sticky black mastic-type stuff when I removed the old unit]
Thanks for people's advice, Ezio
SealedUnitsOnline
