Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
We've got a Vaillant 828E combi with a 110 24hr timer. I would like to upgrade to a 7 day timer. It looks like I might be able to plug in a 120 7 day timer. Is it as easy as that? Is that the best/right replacement? Anything to be wary of?
I've swapped a couple of ford engines. Funnily enough the bolt patterns and engine mounts are fairly common and its not that tricky. Even swapped a petrol engine for a diesel once. Happy to help with your swap if you like. I presume you don't know the answer to my question
this can be done as i have had it done
you must folow the instructions in the installation manual as the timer will have to be put on a wall remotelly and the 7 day timer will aso have to have a temp control on it ( be carful and folow the warnings as there is a chance of blowing all the eletrics when fitting. ( happed ))
refer to page 29 and 30 of instructions for installation and servicing of vaillant and the notes on the unit you have chosen ( i have a drayton unit )
