Replacing Danfoss TP9000MA with Hive
23 Feb 2011
Leicestershire
Hi guys,
I'm hoping this is a simple question.
I'm looking to replace my existing Danfoss TP9000MA with a Hive dual zone system. I have an unvented hot water system so would be buying the dual channel version.
My understanding is that the wiring for the programmer is a straight swap for the Hive with the exception of the two additional wires for the remote sensor. So my question is, what do i need to do with those two additional wires? Just leave them disconnected at the progammer end?
The fact my house runs a dual zone setup with, does this have any baring on the wiring and/or installation? I've not yet been able to find that out. I have a Danfosse wireless controler for the second zone if this makes any difference. I'm assuming that wirelessly connects to the wired controller somehow.
Any help much appreciated.
23 Feb 2011
Leicestershire
I've actually found that my second zone is not wireless. Its a battery powered switch i think - Danfoss TP4000/5000/5000si (one of those according tot he lable).
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
So much depends on the boiler, EPH do a master/slave thermostat that can do two zones with Opentherm, there is another who does a zone system, so three outputs, but for most you need a single central central heating zone.
The idea is the TRV forms multi zones so no point forming sub zones I like the idea of Hive, not a clue if it works, but idea is the Hive TRV head sends a demand for heat to wall thermostat, personally think it is a bit expensive and not OpenTherm plus reports of poor connection to hub, so may need the extra strong hub Hive does, but never the less seems a reasonable system.
I am however a fine one to talk, I went with Nest and it simply fails to connect to the TRV in a reliable way.
