Hi all.
Our house is lit entirely with downlighters, mostly Halogen MR16s but I've replaced the ones in key areas like the hall with LEDs - along with their transformers.
Over the years a number have failed because the electrician didn't use fire rated enclosures (renovation was around 2003 so is it possibly they weren't a requirement then?), neither did they secure the connblocks down so the blocks sat over the lamps, over heated and shattered.
How the house didn't burn down I'm not sure.
I'm now looking to replace the rest but it seems it would be much easier to swap the MR16s out for mains voltage GU10 LEDs.
So here's the question: Can I just replace the lamp and lampholder or should I replace the housings as well with fire rated enclosures? I am hoping because LEDs pump out less heat I should not need to.
Thanks for all the replies.
