Replacing Electric hob
How did you intend to connect new cable to existing ? It sounds like your new hob comes pre wired for a three phase supply. If you can show a pic here of the hobs terminal block and the cables connections to it ,that would be useful ,together with any instructions .
Not sure how you get to three phase supply.
All sorted thanks. According to the electrician the four wire cable is probably meant for overseas connectors so when I linked the two live terminals it all works fine. Thanks again for all your responses.
