Just moved into a new house and found the workshop attached to the side of the main building has a spur running from a socket in a bedroom, out through the wall.. along the side of the property (twin & earth white cable held on with metal cable fixings) into the workshop. which supplies the florescent lighting and mains wall sockets.
So, ive promptly disconnected the spur from the bedroom socket, leaving the workshop in the dark.
I need to reconnect it, but my questions are...
do i need to run a light AND mains supply into the workshop or can just use the single mains supply for the 2 florescent lights as well.
is this setup with an adjacent building, counted as `external` like a shed, is that because my cable would run `external` - if so, could i drill a big hole through the 19" solid stone wall and run the cable `internal` ?
if the cable were to go `external` - could i feed it from a fused spur in the main property, run it along the outside wall at knee height, in a protected PVC trunking and junction boxes ? - or does it need to be above head height and in what type of protection ?
hope someone can give me some pointers.
thanks,
Stuart.
thanks,
Stuart.
