Hi All!
I’ve been researching the installation of hive in place of our current system which is a Honeywell ST9400c.
Our set up is boiler and water cylinder, with two thermostats controlling both upstairs and downstairs.
I’ve pretty much got my head around the process but quickly losing confidence one I crack the junction box and stare at the tin of spaghetti inside. I have the correct hive bits, two receievers (one water and heating, the other heating)
From my understanding I can switch out the Honeywell programmer for the Hive receiver with like for like wiring.
Then I need to address the downstairs thermostat by disconnecting it and capping.
Where I’m losing my head with this is within the junction box, what I’m reading and watching is telling me to trace the wires from stat to junction box to figure which is which, this is not possible without pulling my walls apart.
There junction box has 3 cables running into the back left coming from each of the 3 port valve boxes at the cylinder. Is the thermostat likely to be one of these cables, this doesn’t make sense to me but after that I’m at a loss!
I’ve attached images of the set up at the boiler and the water cylinder (where then junction box lives)
If somebody could break it down for me that’d be great! I’m aware I’m not mentioned the upstairs circuit, I’m just trying to get my head around downstairs first before tacking the second leg of the job!
TIA!
TIA!
