Following on from my previous thread I've decided to just replace the joists and use slate tile to replace the rotten board they sit on.
Looks to be an easy enough process since the masonry pockets are quite deep.
Only problem is that one of the joists has a wall on top.
The wall is single story made of block work and built directly off the floorboards. There is a joist either side of the wall running parallel to it. Is there an easy way to support the wall and pull the joist or am I better off just sistering this one to avoid disturbing anything?
