Hi All,
I've looked through the forum but still wasn't quite sure so thought I'd ask, all advice is greatly appreciated!
We removed a radiator to decorate (from a combi boiler CH system). When went to refill the radiator when it was put back, the shaft on the lockshield valve has sheared off and the valve is stuck closed.
We have a new valve, a hose pipe and have watched guides on draining the system to replace the valve. However -
1. we live in a flat and have identified 2 drainage valves - can we use any valve or a particular one to drain the system?
2. The guides say that all valves should be open to drain the system, what do we do if one is stuck closed?
3. I've read that there are chemicals in CH systems - is it necessary to put them back in when we refill the system?
Many thanks
Many thanks
