Hi All,
I'm currently in the process of ripping the kitchen out of a house I have not long moved in to.
Whilst doing so I have found a leak from a Boss glued to the side of the plastic soil pipe. Water is leaking out of the part where it is glued on. I will not need this Boss when I install the new kitchen as it went to a washing machine, washing machine will be connected via a connector under the sink.
The problem I have is how do I go about fixing the leak? After the kitchen is installed I will not have access to the lower part of the soil stack so I want a good permanent repair.
The pipe that the boss is attached to goes in to a join before going in to the ground at one end and the other end connects to a long boss pipe before continuing up to the bathroom above, so I was thinking of changing this part of pipe. But presumably you would need to lift the whole soil stack up to do this, which sounds like a nightmare.
Therefore has anyone got any suggestions as to the best way to fix this?
Many thanks in advance.
