- Joined
- 18 Nov 2004
- Messages
- 1
- Reaction score
- 0
- Country
Hi, i am replacing two plastic light swtiches with two metal light switches.
The current plastic switches are fitted/wired as follows:
A red wire from the cable (live) connected to the '1way' point and a black wire from the cable (i presume to a switched live- no red tape) connected to 'common' point. There is an earth wire screwed into a point on the back box from the cable. The plastic switches also have a '2way' point next to the '1way' point but there are no wires screwed to it.
The metal switches (VOLEX) have three points plus one for an earth. The 3 points are L1 (top), L2 (bottom right) & L3 (bottom left).
I would like to know to which 'L' points on the metal switches do the live and switched live wires go respectively.
Also, regarding the earth wire, do i have to connect a wire from the earth point on the switch to the earth point on the back box or do i simply unscrew the earth that is screwed to the back box and screw it to the metal swtich plate.
Thanks in advance for your help
