Replacing RMT230 with RET230
16 May 2010
Hi guys
I've got a RET230 to replace my RMT230 which is registering about 5 degrees of the correct temperature (which is driving me potty)
I'd either like to replace my RMT230 or get it to register the correct temp.
Currently the RMT230 is wired as :
CON 4: GRAY (Neutral?)
CON 1: Brown (Live?)
CON 2: Black (On?)
For the RET230 - I think it should be:
Neutral: Gray
Live: Brown
3 (On): Black
Do you think this should be correct?
2, 3, 4 are voltage free contacts, therefore you will need to link L and 2 to get power from 4.
Sorry - I'm not following you - on the RET230, the are no pins for connections 1 and 2.
Also, I've just noticed that for the RMT230, the diagram inside the unit indicates that Neutral is commoned between 2 and 4.
Does this sound right?
That would imply that Gray and Black should be commoned together - but that doesn't sound right to me.
No they are not, Have a good look.
Neutral: Gray
Live: Brown
3 (On): Black
If the model number is just RET230 and not one of the variants. e.g RET230-C3 or RET230LS etc, then your wiring is correct.
Thanks for that - both models are the base model.
I will give that a shot when I get home from work tonight.
When I had the front plate off last night, I noticed that there is a thin sheet of metal behind the dial, and presume that the expansion and compression of this plate controls the detected temp. This thin sheet has been bent, and would this cause it to detect the wrong temperature?
I would provide a photo if I could find my camera to illustrate this! ;)
Thanks for your responses.
Cheers
Scott
