Coldest day of the year so far and problems with lukewarm radiators and hot water. Boiler fires up and runs for around 7 minutes prior to dropping back to a pilot light. Have tested the over heat thermostat and main thermostat, problem appears to be the solenoid on the gas control valve.
Gas Control valve is a green button Honeywell V4700E
The solenoid is 240 volt SOLENIOD COIL V4700E GAS VALVE 45900406-003
Just not sure how to remove the old solenoid from the gas control valve, anyone replaced one of these parts before?
