Replacing Switch with Power Socket
29 May 2010
Cleveland
Hi
Our flat has several electric heaters on the wall and we removed one a while ago.
I want to replace the switch with an electric socket - can I do this? It will be on the same circuit as the other heaters?
Are the heaters fed from an off peak supply?
Can you isolate the circuit feeding the heaters from the same distribution board as your power and lighting circuits?
Hi
All the heaters are on the same fuse on our consumer unit if that helps?
Apart from that not sure what you mean sorry?
What type and size of fuse?
Can you determine the size of the cable used for this circuit?
How many heaters are on this circuit and what is the power consumption of each heater?
Hi
Thanks for replying
There are 3 x 750W heater and 1 x 1500w heater on the circuit. This switch used to have a 750w heater attached to it.
The cable looks like standard electic cable with 2 x live, earth & neutral coming in.
The fuse in the switch is 13A
Thanks!
All the heaters are on the same circuit. The other power sockets in the flat are on a seperate circuit.
The fuse rating in the consumer unit is a B32
Are there two wires in the mcb?
If there are and as you have already said there are two wires at the switch (where you want to put the socket) it would appear to be a Ring Final Circuit in which case it would be alright to replace the switch with a socket.
However, I would advise you to find out for certain by having an electrician test it because if it is not a RingFC it may have been installed incorrectly and be dangerous.
