Request: Glow worm betacom 30 MI's
29 Jun 2006
anyone got a link to the mi's for this boiler? (not the new 'c' model)
wanted to check part numbers on flue parts.
the boiler will be installed betwwen 670mm gap between a 3storey internal corner and an openable window, so i'm planning on using a plume management and 45's to swing the outlet away from the internal corner and above the window.
also need a 1m 100mm extension (2ft solid walls :( )
cheers
same flue system as all glow worm/vaillant range.
is that definate, for the 'older' betacoms?
thanks for all the advice Dangermoose :D
yes deffo the same mate. make sure you fit the flue restrictor though (if needed) overwise ign lockout probs.
ok, cheers.
do you/have you fitted these?
best price i can find (eBay) is £430 inc Vat and delivery £40 (boiler, standard flue and mechanical clock) do you think i'll get it cheaper at plumbs/pts etc?
cheers again.
fitted a few but not my prefered boiler by any means. those prices are about right.
