Residue in kitchen sink after washing machine load.
26 Jul 2013
Surrey
Did my first machine load since new boiler and noticed that residue had been pushed up the kitchen sink which I can only assume is related because the sink was clean before I turned on the washing machine.
Is this normal?
Can't see why a new boiler would have any effect unless the condensate pipe has been tapped into the sink waste and is causing some obstruction.
I believe this has been done. Is it something to be concerned about?
I don't mind a bit of dirt being thrown out of the plug hole as long as something worse isnt brewing...
When BG fitted my new boiler they used a self cutting tee to splice into the bathroom basin waste.
These sort of self cutting wastes can leave a flap of pipe hanging inside the pipe usually not a problem but in some circumstances might allow debris to lodge and cause a blockage.
I would get your boiler installer back to check the waste is not being restricted.
I'm with footprints on this.
I doubt that its the condensate causing the difficulty, but rather, the re-arranging of the trap and spigot(s).
There is also the possibility that when running the condensate pipe the w/m waste has also been rearranged - it should run high before dropping down to its spigot.
Sometimes, fitting a 40mm AAV on the trap arm solves a backing up issue.
Hi Andy,
Ex Corgi fitter 31 years BG & 5 self employed.
I now have to stand and watch a schoolboy from BG fit the boiler in my rental, in order to conform to the rules!
Thinking "you don't want to do it like that" :D :D
footprints
