To the best of my knowledge, even in the absence of auto-ranging, virtually all of even the most expensive of devices sold as "multimeters" (which commonly claim resistance measurement up to something in the 20MΩ - 50MΩ range) use the same very low voltage (typically ≤3V) for all resistance measurements. That is, for example, true of most/all of the most expensive devices Fluke sell as "multimeters".I have a meter to measure resistance, the low range uses at least 200 mA to measure with which is required by regulations, and the high range uses 500 volt to measure with, again as required by regulations, I can't see how any meter could combine the two.
There are a few exceptions, in the name of "Insulation Multimeters" or suchlike (like the Fluke 1587FC) which (separate from the 'normal' resistance measurements) do high resistance measurements at voltages up to 500V or 1000V, but they are very unusual, and expensive for what they are - I imagine that most people would use MFTs or standalone IR testers for that purpose, not a 'multimeter'.
Kind Regards, John
