Hi
We've got a sink that's all built in and while it has fairly easy access from under it, the cupboard below has been cut to fit the sink.
The sink it's self is fine, good size, fits nicely in place. BUT it's got 2x taps, one hot one cold.
The taps are connected via flexihose which makes the job easier and one of those hoses has bust and the hot tap is also dodgy and has been for while.
SO, I thought if I'm going to replace the hose, I may as well replace the tap at the same time.
THEN I thought, if I'm going to replace the tap... a mixer tap would be nice.
But I don't want a mixer tap on the left or right it should be in the middle.
SO, without replacing the entire sink, is it possible to drill a hole in the middle of the porcelain sink and pop a mixer tap there, then plug the 2x holes?
If so, what drill bit would I need? Ideally I don't want to crack the sink(!)
If not, it's no biggie, it was just an idea
