Hi all,
I would like to retrofit smart heating controls to my central system.
System is pretty standard OFCH with (wet) underfloor heating downstairs (7 actuators, 6 analogue stats), 6 radiators and 2 towel rails upstairs (single analogue thermostat in landing) and a large hot water tank (single analogue stat on tank). Control is via a Horstmann 3 channel programmer.
Heating controller is located in utility room next to back door. Wiring center, UFH zone valve, UFH pump and manifold for underfloor heating is in cloak room, along with zone valves for radiators and hot water.
I had been looking at replacing ALL my controls with a Heatmiser neo system based around wired neoStats for room stats and upstairs stat, going to a UH8 wiring center and associated neoHub for remote control via smartphone. However looking through the documentation I can't see how I can control all 3 loops of the system correctly. While the UH8 can assign zone 8 for radiator control, surely using one of the other zones for hot water will switch on the UFH pump when the tank stat calls for the hot water tank to be heated?
The only way I can see around it (not fully understanding the Heatmiser system as yet!) is to continue to use the Horstmann controller for timed hot water and just pass through (always on) control of the UFH and radiators. But loosing remote hot water control seems a bit daft. I've probably missed something along the way!
Any suggestions? Or suggestions of a more appropriate system than Heatmiser for my purposes?
