    Dismiss Notice
Reverse acting thermostat
Discussion in 'Plumbing and Central Heating' started by Geoff Forrester, 19 Mar 2018.
  1. Geoff Forrester
    Geoff Forrester
    19 Mar 2018
    3
    Thanks Received:
    Country:
    We have a multi fuel stove which does the central heating. Which at night if we are not careful will overheat. I wish to put a reverse acting thermostat near the stove to prevent the water boiling over. We have a thermostat which controls the central heating pump. The thermostat is turned down at night. Could I put a live wire to a reverse acting thermostat and then a wire to the pump. Then when the reverse kicks in it will start the pump to stop the water boiling. Will this be safe
  2. Dan Robinson
    Dan Robinson
    1 Jul 2007
    56,042
    Thanks Received:
    9,424
    Hertfordshire & London
    Country:
    No solid fuel system should rely on electricity to be safe.
  3. Geoff Forrester
    Geoff Forrester
    19 Mar 2018
    3
    Thanks Received:
    Country:
    Sorry but you have to have electricity to run the central heating pump.
  4. Dan Robinson
    Dan Robinson
    1 Jul 2007
    56,042
    Thanks Received:
    9,424
    Country:
    No schit?
    • Like Like x 1
  5. muggles
    muggles
    28 Oct 2005
    11,411
    Thanks Received:
    2,327
    Daventry
    Country:
    Yes you do need electricity to run the pump, but Dan is quite correct in what he says - a properly installed and set up solid fuel heating system MUST be able to dissipate the heat it generates in the event of a powercut...IE it shouldn't be able to overheat when you have no power. Relying on electrical systems to dissipate heat isn't considered safe and does not comply with regulations
  6. Geoff Forrester
    Geoff Forrester
    19 Mar 2018
    3
    Thanks Received:
    Country:
    When you get a power cut you have to dampen the stove down and life the lids to let the heat out and there is on other way of doing it unless you have a generator. I don't think you have had many power cuts and I don't know which regulations you are talking about There is none like that in the UK
  7. Dan Robinson
    Dan Robinson
    1 Jul 2007
    56,042
    Thanks Received:
    9,424
    Country:
    Prat.
    • Like Like x 1
  8. muggles
    muggles
    28 Oct 2005
    11,411
    Thanks Received:
    2,327
    Daventry
    Country:
    I'm fully HETAS qualified for both dry and wet stove installations. I do know what I'm talking about. Suit yourself though, if you don't want to take advice from professionals then off you trot, I'm sure someone somewhere will be happy to tell you what you want to hear
    • Like Like x 1
  9. Sponsored Links
  10. FiremanT
    FiremanT
    16 Jan 2012
    8,078
    Thanks Received:
    1,535
    Uk
    Country:
    Wheres Bernie when you need him? ;)
    • Like Like x 1
  11. big-all
    big-all
    12 Jul 2004
    17,916
    Thanks Received:
    1,354
    Surrey
    Country:
    part j building regs
    https://www.gov.uk/government/publi...-and-fuel-storage-systems-approved-document-j
    • Thanks Thanks x 1
  12. baldykev
    baldykev
    30 Sep 2011
    84
    Thanks Received:
    17
    Hampshire
    Country:
    Sorry but you DO need a thermal dump in case of power cuts or pump failure. I looked into this when I installed my log burner.
  13. AdvanceHelpline
    AdvanceHelpline
    5 Sep 2016
    28
    Thanks Received:
    4
    Country:
    There's no reason why you can't fit a pump, but these chaps are correct - you will also need a mechanical safeguard like a thermal safety valve and discharge/quench arrangement that works without power.
  14. bernardgreen
    bernardgreen
    3 Nov 2006
    22,725
    Thanks Received:
    2,140
    Bedfordshire
    Country:
    A thermal dump has been mentioned, that uses gravity to create circulation from the boiler to a thermal dump which should be large enough to dissipate the heat from the log burner with a full loading of logs. ( worse case ) For a small log burner this could be a large radiator. For a large burner a tank of sacrificial cold water may be necessary to remove heat from the heat dump. Sacrifical as when heated it is dumped into the drains. The control of this must NOT require an elecrical supply
    I was needed elsewhere, sorry. Though you seem to have the matter in hand. :mrgreen:
  15. Nozzle
    Nozzle
    23 Dec 2012
    2,061
    Thanks Received:
    260
    Suffolk
    Country:
    Natural Circulation. Heat source down low, heat sink up high, fully primed system, minimise the friction in flow and return.
    Job done.
    There's nothing stopping you have a pump IN ADDITION, but that's very different from having to rely on it for safety.
    Nozzle
  16. bernardgreen
    bernardgreen
    3 Nov 2006
    22,725
    Thanks Received:
    2,140
    Bedfordshire
    Country:
    The problem with that is that the pump at standstill ( no power ) creates friction that reduces natural ( thermal ) circulation.
Loading...
Share This Page
